spqr105
Mar 24, 2021Tutor
RBR50 dropping some 5Ghz internet connections
Hey guys, So over the past 2 weeks certain 5ghz devices such as my smartphones, ring doorbell and devices hardwired to 1 RBK50 satellite (we have 2) have randomly been dropping their internet conne...
Mar 24, 2021Guru - Experienced User
Is the Orbi syste
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- spqr105Mar 24, 2021TutorFirmware ends in 104 for router and satellites.
ARRIS SURFboard SB6190 DOCSIS 3.0 Cable Modem and is working fine.
Home is 4500sqft and there is about 50ft between the router and satellites.
My nearest neighbor is 300ft from my house. I have experimented with all of those configurations you mentioned.- FURRYe38Mar 24, 2021Guru - Experienced User
Might bring in the RBS to say 40-45feet and see.
Try some of the suggestions. IF a reset hasn't been done, I would try this first off.
Also besure that Traffic Meter is disabled.
- spqr105Mar 24, 2021TutorSomeone else on reddit mentioned a traffic meter bug. Did this just start and is it known to impact internet connectivity? I have it enabled. Thanks.
