ngautobot
Mar 18, 2021Tutor
RBR50 Drops after firmware update
Hello, I just updated the firmware in my RBR50 to V2.7.2.104. After this, my internet connection frequently drops. I didn't have this issue before the firmware update. The update was successful. ...
DJMarc127
Mar 19, 2021Initiate
For the past two weeks, the RBR50 keeps dropping my internet connection. My AT&T router allows me to connect with max speeds but only when I'm closer to the router. Netgear/Orbi - you've got a problem it appears. My Orbi Wifi has been SOLID for 3 years up until the past two weeks and the latest firmware (V2.7.2.104)got installed. :-( :-( :-( YES, if I restart and reset the RBR50 router, it will reconnect but then within a couple of hours, it will disconnect. NOT GOOD!!!
My family and I am really getting frustrated!! HELP!!!!
- vajimMar 19, 2021Master
DJMarc127 wrote:For the past two weeks, the RBR50 keeps dropping my internet connection. My AT&T router allows me to connect with max speeds but only when I'm closer to the router. Netgear/Orbi - you've got a problem it appears. My Orbi Wifi has been SOLID for 3 years up until the past two weeks and the latest firmware (V2.7.2.104)got installed. :-( :-( :-( YES, if I restart and reset the RBR50 router, it will reconnect but then within a couple of hours, it will disconnect. NOT GOOD!!!
V2.7.2.104 is faulty.....revert back and wait until things get sorted out
- ngautobotMar 25, 2021TutorYeah, it's got to be the firmware. This newest version is completely buggy. Everything was perfectly fine until I updated the firmware. It's not in any other settings. How do I revert back to a previous firmware version?
- vajimMar 25, 2021Master
ngautobot wrote:
Yeah, it's got to be the firmware. This newest version is completely buggy. Everything was perfectly fine until I updated the firmware. It's not in any other settings. How do I revert back to a previous firmware version?If you've already tried all the great suggestions on how to fix the problem, yoyu can go to the download section, enter your model number and see what's there.
Good luck
