ngautobot
Mar 18, 2021Tutor
RBR50 Drops after firmware update
Hello, I just updated the firmware in my RBR50 to V2.7.2.104. After this, my internet connection frequently drops. I didn't have this issue before the firmware update. The update was successful. ...
andybrwn
Mar 21, 2021Guide
So I rolled back the firmware. I also ended up swapping out my old comcast cable service for att fiber. The att modem has its own router, so by RBR is now in AP mode. No issues now, but its also not doing the routing work, just the wifi work.
Curious to me that on the RBR GUI its doesn't say to update the RBSs first--but its plain as day in the manual.
Mar 21, 2021Guru - Experienced User
Next time try disabling Traffic Meter if your using it or DST. Others reported this solves the problem on v104.
andybrwn wrote:So I rolled back the firmware. I also ended up swapping out my old comcast cable service for att fiber. The att modem has its own router, so by RBR is now in AP mode. No issues now, but its also not doing the routing work, just the wifi work.
- vajimMar 22, 2021Master
FURRYe38 wrote:Next time try disabling Traffic Meter if your using it or DST. Others reported this solves the problem on v104.
Doubtful
