ff69
Jun 16, 2020Aspirant
RBR50 Drops Connectivity and keeps rebooting - very unstable
RBR50v2 connected to a SB8200 Modem. Device configured with 1 satellite. 5 Wired connected PC and devices (ROKU). 3 5GHz wireless devices and 2 2.4 GHz (Thermostat Honeywell and Ring) Main R...
Jun 16, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
ff69
V2.5.1.16
Other side of the House, one level below (so at least 40ft)
Currently Manual on 2.4GHz = 11(P)+ 7(S)
5G Channel 36+40+44+48(P)
Lots of wifi neighbors but spread 1-2 per channel (27 different signals detected)
WMM enabled on both 2.4 and 5 GHz
Beanforming enabled
MIMO -> Set to Enabled
Preamble -> Reset to short on both
CTS/RTS is 2341 0n 2.4
CTS/RTS is 2345 on 5
Has Power at 50% on 2.4 ->100%
No Armor
No Daisy Chain
No Fast Roaming
No IPv6
No coexistence
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Rebooting...
- FURRYe38Jun 16, 2020Guru - Experienced User
- ff69Jun 16, 2020Aspirant
Rebooted.
Satellite repositioned and now Blue - (instead of Magenta) - show online on the phone app
All devices properly connected.
So far connection status show 13:38 up time. So no apparent drop since reboot.
Also Telnet a different value before for the lease length - 86400 -> 1200
