markdmumy's avatar
markdmumy
RBR50 drops internet at night
I have ATT internat at home that is conencted direct to my RBR50 and then on to other satelites.  For the past week (likely since the latest firmware update, though I can't say for sure), my Orbi seems to stop all activitty from about 10p to 5am.  Every night for the past 6-7 nights.
Side note, my ATT router is configured for wifi that I use solely for wifi devices (ring, sprinkler control, security system, etc).  I've hidden this SSID from broadcast since it is just for devices that I set up.
I also have Circle enabled on the RBR50 but only for kids devices.
What do I mean by all activity stops?  The Orbi is still powered on and my devices can even join its wifi.  Once connected to my Orbi, though, I cannot even log in to the admin page via the app or browser.  Wireless or wired.
My iphone (which Circle is set to ignore) is connected to my Orbi wifi but shows "no internet available".  When I switch my phone to my hidden wifi SSID, it works perfectly.  Tells me that the internet is just fine since I can connect direct to my cable modem and get online (wireless or wired).
On the Orbi, I see nothing in the logs other than these types of messages:
[DHCP IP: 10.0.0.12] to MAC address f0:a3:5a:92:84:b9, Thursday, August 13, 2020 23:49:48
[DHCP IP: 10.0.0.10] to MAC address 90:e2:02:ae:a5:3d, Thursday, August 13, 2020 22:33:53
I can also get on my laptop which is hardwired into the Orbi and it is offline as well, no internet.  If plug my LAN cable direct into the ATT router, it's online.  Seems to be limited to Orbi/Circle but this has been fairly solid.
I've even rebooted the Orbi and ATT modem.  ATT comes back online just fine, but Orbi still has the same issue.  A reboot doesn't clear it up.  On my ATT router, I can see the new connection from the logs as well as see the activity lights on the LAN connections.
This setup has been working flawlessly for 3 years now since I installed it.  No changes to my ATT router or to the Orbi other than the infrequent firmware upgrades that happen.
Initially, I thought that I had perhaps done something with Circle that shut things down at 10pm, but I don't see anything in there that is doing this other than two profiles I have for my kids devices.  One takes everything offline from 9p-6a and the other goes offline form 12a-5a.
I've even gone through a factory reset of all Orbi devices, but it still happened.  Not quite sure where to look.  The Orbi logs are just about useless and don't have much to show in the way of things going offline or online other than the DHCP notes above.
I am at my wits end on this.  Any ideas as to where to look?  I've seen lots of issues with the latest firmware, so maybe a downgrade is warranted?
Thanks!
Mark
  • It is odd that it is a timed disable, maybe because of a setting. Has anything else changed other than recently upgrading the firmware?
    Is your Orbi is router mode? If so did you assign a static IP from your router, as maybe it's losing its assigned IP address from the router, therefore will not connect to the internet.
    • markdmumy's avatar
      markdmumy
      Yes, my Orbi is in router mode.  I've assigned it an IP address, so no changes on that front, it is static.
      Wouldn't a reboot of Orbi clear that up, though?  After reboot, it would have gotten a new IP address if it were on DHCP.
      Nothing else has changed, that's the discouraging thing.  At least not from inside my house.  I'm in IT, have been for 25 years, and have this locked down so that the family can't get in and change stuff.  That's what so odd about it all.  I really am at a loss as to why it's happening.
      • Mstrbig's avatar
        Mstrbig
        Master
        Sometimes routers and even NICs can be fussy. I've had PCs lose internet and nothing but literally unplugging the power for over a minute gets rid of whatever is stuck in the memory of the NIC.
        Being IT for 25 years you know it's more than likely a changed setting, whether man made or due to hardware or software addition, change or activation.  Because to be honest, I don't think it has to do with the physical Orbi RBR50 or it's firmware at all. Must be a setting, if the internet shuts down every day at the same time, for the same length of time, as you posted in the OP. That sounds like a man or software made schedule. I always say what's the last thing I did right before the problem started.
        In your OP you say "my Orbi seems to stop all activitty from about 10p to 5am."
        Then you say "I don't see anything in there that is doing this other than two profiles I have for my kids devices. One takes everything offline from 9p-6a and the other goes offline form 12a-5a."
        This confuses me as you are saying you are shutting everything down from 9pm to 6am? Have you turned off this feature?
        If it was my system, I'd start from a simple setup, disabling all features, bring down to a textbook setup, and disconnect all devices except one. Sooner or later you'll find what's causing it.
