markdmumy
Aug 14, 2020Aspirant
RBR50 drops internet at night
I have ATT internat at home that is conencted direct to my RBR50 and then on to other satelites. For the past week (likely since the latest firmware update, though I can't say for sure), my Orbi see...
Jan 22, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Nchampion wrote:
I have the same issue except my Orbi drops internet at 3:30 am. Did you ever find a resolution? I am operating under the theory that I have too many devices on the network. I have ordered an additional satellite (I have 1) in order to support more devices and I hope that works. Based of your issue, I’m less convinced that an additional satellite will solve my issue.
vajim
Jan 22, 2021Master
all of this behavior sounds like it may be related to firmware
