Wolverine777
Feb 01, 2021Follower
RBR50 Drops Wifi periodically
I have a RBR50 router with two RBS50 satellites, plus a RBS50Y outdoor satellite. The indoor router and satellite equipment is on the latest firmware 2.7.2.102. The outdoor satellite is on 2.6.1.40...
Feb 02, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Are the RBS wired or wirelessly connected to the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
