edthesprinter
Apr 25, 2020Aspirant
RBR50 Drops WiFi Roughly Every 6 Days
Hi, About every 6 days, my ORBI RBR50 WiFi stops. I have to reboot to get things going again. Anyone else having the same issue? Firmware version is V2.5.1.8
Apr 25, 2020Guru - Experienced User
This isn't a FW issue. More like a interference issue or configuration issue.
Also there is newer v16 FW available as well to try...
