angr
May 13, 2019Star
RBR50 Eth cable Connected Devices not accessable from Satellites
I'm having an issue where my Synology NAS, attached via Ethernet cable to my RBR50 router is not properly accessible via the Orbi Satellites (RBS50/RBS40).
When on my laptop and connected to t...
angr
May 13, 2019Star
As further explanation - I can reach other Orbi connected devices also when connected to the Satellites, and internet connectivity also works fine. It's the cable-attached NAS that is unreachable on Satellite-connected WiFi since v .48.
May 13, 2019Guru - Experienced User
Is Daisy chain enabled? Try a disabling if it is.
Try a reset if you have not since updating.
