wjbonds
Feb 16, 2021Aspirant
RBR50 expansion
Hi all and thanks in advance. I have the Orbi RBR50 router with one RBS50 satellite. Home is 3000 sq. feet with several interior walls. Modem speed currently is 200 MbPS through my cable provider (...
vajim
Feb 16, 2021Master
did we identify the modem?
wjbonds
Thank you - Modem is an Arris TM804
- vajimFeb 16, 2021Master
wjbonds wrote:Thank you - Modem is an Arris TM804
that modem has the telephony support? Not sure that it will work with the Orbi.
The only NG modem that supports phone is the CM1150v;
https://www.netgear.com/images/datasheet/networking/CableModems/CM1150V.pdf
