presidentskroob
Jul 18, 2018Tutor
RBR50 experiencing slow wired connection and frequent router reboots
I purchased the RBR50 some months ago, and I've recently begun to see two significant issues, one that I think people have quite a bit of experience with (frequent router reboots, even on the latest ...
Jul 18, 2018Guru - Experienced User
Are these the only devices connected to the orbi?
Whats the Mfr and model# of the ISP modem the Orbi is connected too?
I would do a Factory erase and set up from scratch. I would first set up the router, dont' enable the speedtest app on the router. Just set it up and run a couple of tests from the PCs first...
presidentskroob
Jul 18, 2018Tutor
These are the only two wired devices, but there are about twenty other devices on the network, mostly IoT stuff but also our work laptops and various other things connected to either the router or one of the two satellites.
The ISP modem I do not believe is related, as it's been happening with two different ISP modems. That was the first thing I expected to be the culprit, and I was due for a modem swap due to upgrading to the 200mbps plan about a month ago. After swapping the modem, though, the same problem persists.
