Bobnicolas
Apr 18, 2021Aspirant
RBR50 extend satellite to satellite
Hello, I am trying to set up my orbi configuration a specific way and face issues. I d need to know if that is doable : I have a RBR50 in a room. I have 2 satellites in 2 other places in the ...
CrimpOn
Apr 18, 2021Guru - Experienced User
Yes, one satellite can be linked to another satellite with ethernet. The second image on this page shows it:
What the web page does not illustrate is that the first satellite can be connected over WiFi or ethernet (either way).
I suspect there may be an issue with the ethernet wall jacks or ethernet cable. Try bringing the new satellite into the same room and connecting it with a short ethernet patch cable. Then connect a computer (laptop?) directly to the new satellite with ethernet and check speed.
Because so few laptops/tablets, etc have ethernet jacks these days, I bought a USB/ethernet adapter for about $15 on Amazon so that I can test ethernet when I do not have a device handy with an ethernet jack.
Bobnicolas
Hello
I made some more tries on this setting with no luck.
Just for a recap and maybe better explanation, here is what i would like to do :
RBR50 ==========WIFI========= 1st RBS50 (Here OK)
WIFI
2nd RBS50 ======== ETHERNET ======== 3rd RBS50 (This one i got 8mb/3mb).
I have on the admin gui :
1st RBS50 working perfectly. high bandwith when connected on it.
2nd RBS50 working also perfectly, bandwith is normal on it too and as above shows 5ghz icon.
3rd RBS50 working bad, bandwith bad and showing wired icon and shows connected to the RBR50. (it is a point i find weird as i would expect to see it showing connected to RBS 2nd.
Do you think enabling Daisy Chain could help in any way ? or maybe, i remove all the RBS from the router, (reset them) then sync the first one, then i plug the 2 remaining in ethernet (2nd and 3rd) and switch them on this way to see what i end with ?
Thanks for your reply
Regards
Edit : Just to let you know also that i tried another ehternet cable, with no luck. i need to try your other advice, plugging the computer with ethernet usb adapter directly on 2nd RBS and also 3rd just to see if bandwith is any better.
In my case it just looks like the 3rd RBS is anyway trying to get wifi from another sat or router and then i end with bad bandwith.
ethernet in between 2 satellites is maybe not working the way i think it does and i would need another access point with like same SSID / pass to have a real wifi sent in the room. i got another router so i could try also.
- BobnicolasApr 19, 2021Aspirant
Hello,
I could not edit my last reply, i tried on ethernet on first sat, and the sat in the room.
i got like 650/550 on each, so bandwith is here. it is just like the 3rd sat is sending wifi he caught from any other sat and then the bandwith is very low as it is exactly the reason why i wanted to wire those 2 sats together :).
Thanks
Sorry for the flood,
I finally was able to connect this way.
I went to the GUI and deleted all the satellites (3) from it.
Then i added the first one to the RBR50, and placed it where i wanted it to be. i switched it off.
I synched the second one, did same, and finally third one.
I switched them on all at once, without the ethernet plugged first, waited for the settings to be set and the network to look ok.
Then i took the 2 satellites i wanted linked by ethernet and i placed them one aside the other, and plugged the ethernet cable. Switched them on and waited for configuration.
i placed them where they had to be, ethernet plugged and switched them on.
Now it is the "tricky" part to me. in the gui, when you look at connected devices, you see one connected to the other, and the other connected to router.
It has to be the right chain described, so i plugged them differently again till i seen my closer sat connected to the router, and the further one connected to the closer.
Went to test and got abt 450/450, paying attention that my test device was well connected to the further one.
