AHoeger56's avatar
AHoeger56
RBR50 Extender
Hi,
I am from Germany and very new in the USA and I have a question. I use the Orbi RBR50 Router and an Extender (Satelite).
I want to expand my range and want to buy a new 2nd Extender (Satelite). But I can't find anywhere such an Extender.
What has happened? Is this model, I bought only a few month ago so old, that it will not be supported? And if this is the case, which expander I shall buy, that's fit to my system?
Thanks for a reply.
  • FURRYe38's avatar
    No, RBRs can only be used as routers or in AP Mode.
    RBS20, RBW30, RBS50, RBS50Y, EX7500, EX7700 and EX8000 will work as extenders.
