Bongobong
Dec 26, 2022Tutor
RBR50 extending connection outside plus inside guest house?
Hello, I have a RBR50 with excellent coverage inside our main building. Now we would like to extend the WIFI to also outside the building and inside the guest house 15 m from the main building. ...
Bongobong
Dec 27, 2022Tutor
Thank you CrimpOn,
An ethernet cable is not an option in this case, so great to hear that it could be a solution to place satellites in windows.
Do you think there would be any advantage to place a RBS50Y unit on the outside of the main building instead of having a satellite inside? (the signal would have to cross the outer wall anytime, anyway)
Kind Regards,
Erik
Dec 27, 2022Guru - Experienced User
What are the exterior walls made from? Thats a bit of a key.
Another easy check (very rough check) to see if it'll work is to take your phone (if its halfway newer) and go to where you're going to be placing the satellite. See if it has a connection and what speed its at. If its pretty solid speeds, the satellite should work fine. If its pretty crap, then you might have issues. The router/satellites still need to use that wireless backhaul so if you're phone doesn't have a good connection, its a bit doubtful if the satellite will. The satellite on the 50 series has a wider backhaul being 4x4 so it'll be a little more tolerant than a 2x2 in a phone but it gives you a rough idea.
- BongobongJan 22, 2023Tutor
It took a while but eventually I found two RBS50 satellites on the second hand market.
I placed one of them inside in the corner of the main building and the second one inside the other building. When connecting both satellites to the RBR50 router they did not form a Daisy Chain, which would make sense since the second one is further away from the router, but both connect to the router individually.
Does this mean that the signal to the second satellite, further away from the router, is so strong that a Daisy Chain is not needed? Or, do you think it would make sense to force the satellites into a Daisy Chain network?
Thank you for any advice in advance!
- plemansJan 22, 2023Guru - Experienced User
Test the speed on the one in the garage and see how it performs. It might not need a daisy chain.
but it can dynamically change to daisy chain if needed. so it doesn't hurt to leave it there if you're speeds are good.
- CrimpOnJan 22, 2023Guru - Experienced User
Alas, there is no mechanism to force satellites to connect in a specific way except that the original Orbi (which you have) has an option to disable the ability to use Daisy Chain. (newer models removed that option entirely). The system does what "works best" according to some internal programming logic. Since it apparently is not using Daisy Chain, then disabling the ability would be pointless.
