jdanham's avatar
jdanham
Guide
Jun 22, 2021
RBR50 Factory Reset does not work!
I have an Actiontec T3200 provided by my ISP, and I have been having some performance issues with the ISP router wireless running with the Orbi Mesh, so I decided to disable the ISP modem wireless ra...
  • FURRYe38's avatar
    Jun 23, 2021
    If you can access the RBRs web page, try using the ERASE function under Advanced Tab/Backup. Try this with the RBR disconnected from the ISP modem and all other wired devices accpet for 1 wired PC.
    Pressing the reset button for 15 seconds in back of the RBR then release should reset the RBR.
