Ergates
Jun 21, 2022Aspirant
RBR50 Firmware - Conflicting Info
Hi Community, My Orbi says it's up-to-date... But I'm not sure... Grateful for any advice, thanks. Rgds, Andy
- Jun 21, 2022
You're a version behind but I wouldn't necessarily be in a rush to update as we've seen a few stability issues on the newer version.
You can always make a backup and try manually updating if you want to be on the newer version.
Jun 21, 2022Guru - Experienced User
Ergates
Thanks for the reply. I'll wait I think...
