ovrdrvn
Apr 24, 2022Aspirant
RBR50 Firmware 2. 74.24 Rebooting
Latest firmware and my system is beyond unstable. Lose WiFi and satellite disconnects over and over. Ideas and why can’t. Netgear manage firmware testing better??
After updating, did you try a factory reset? its one of the first things we recommend if there's issues after an update. If that doesn't help, we usually recommend reinstalling the firmware in case something was corrupt in the install process
I didn't see this on my RBK50 after loading up v.24...
- KevinLiTNETGEAR Moderator
Hello ovrdrvn,
I understand that you believe the firmware v 2.7.4.24 is unstable for your device. To rectify this issue please download the firmware from NETGEAR and manually install it on your RBK50.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#RBR50%20(Orbi%20Router)%20Firmware%20Version%202.7.4.24
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Please let me know if this helps!
Best,
Kevin
Community Team
