JBuddenbrooks
Aug 18, 2022Guide
RBR50 Firmware download via ethernet to modem
Today, for the first time, I received notification of the availability of Firmware updates (2.7.4.24) to my RBR50 and RBS50s. IThe email notification is much appreciated but I am puzzled why I've nev...
JBuddenbrooks
Aug 18, 2022Guide
Hi Kevin:
I appreciate you fast response. However see the following from the Netgear Firmware update instructions:
"Using a computer that is connected to your Orbi router via an Ethernet cable(wired), launch a web browser from a computer.Note: Do not use a computer that is connected wirelessly to the router to uploadthe firmware. A wireless firmware update might corrupt the router’s firmware,rendering it unusable."
It seems to me that connecting to my cable Modem directly would be okay, perhaps even better. Your comment about using a wireless connection seems to be at odds with their instructions. Am I misunderstanding something?
KevinLiT
Aug 18, 2022NETGEAR Moderator
Hello JBuddenbrooks,
Please provide the link to where you found that information.
Best,
Kevin
Community Team
- JBuddenbrooksAug 18, 2022Guide
It's under item 2. in "To download the firmware for your Orbi router and satellite"
- KevinLiTAug 18, 2022NETGEAR Moderator
Thanks for providing that information!
To be absolutely safe and to mitigate the possibilities of corruption during updates then ethernet cable is advised. Even though the Orbi systems can be updated wirelessly best practice is to use an ethernet cable.
Best,
Kevin
Community Team
