phlying1
Oct 04, 2023Aspirant
RBR50 Firmware downloads the wrong file (RBR50V2)
The download to manually update my RBR50 (https://www.netgear.com/support/product/rbr50#download) downloads the wrong file. It downloads RBR50V2 and then the manual updload fails. Please provide t...
- Oct 06, 2023
If you can get it connected to the RBR or connect it via ethernet to the RBR, log into it's web page and get it updated manually.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
phlying1
retail
Oct 04, 2023Guru - Experienced User
do the older versions work
got a screensnip of its status page showing its current firmware version?
- CrimpOnOct 04, 2023Guru - Experienced User
plemans asks a relevant question. (What firmware is currently installed on this router?)
When the original Orbi was first released, the designers calculated the maximum size that a future firmware file could be and built a test into the update function. Firmware files larger than that limit were rejected. Then, Netgear decided to add Parental Controls, Ookla Speed Test, and Armor functionality to the router, and the resulting firmware file was larger than the limit. Netgear released a special version of firmware that had only one change: it upped the size limit on firmware files.
If the existing firmware is earlier than v2.1.2.212, then this firmware must be loaded before any more recent versions will be accepted:
https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212
- phlying1Oct 05, 2023Aspirant
God I hope that works (the earlier version prior to the size restriction). I will try it. I tried a different browser but that did not work. Thank you.
- FURRYe38Oct 05, 2023Guru - Experienced User
Can you tell us the FW version that is actually loaded on the RBR now?
- phlying1Oct 06, 2023Aspirant
current fW on the router is V2.0.0.74
- FURRYe38Oct 06, 2023Guru - Experienced User
Ok, ya, you'll need to get v.210 or v.212 installed on the RBR then you can go directly to most current seen here in the forums. I recommend updating ANY RBS FIRST, then do the RBR lastly.
ALL FIXED! Thank you! I never would have figured that out in a million years.
I got one RBS up to date and the other is on way old firmware. I don't really need a second one but is there a way to get that one caught up now that the router is on FW V2.7.4.24?
Enjoy. 📡 - KevinLiTOct 07, 2023NETGEAR Moderator
Hello phlying1 ,
I understand that the firmware on your satellite is older than the firmware on the router. Incremental updates may be needed to get your satellite caught up to your router. The proven best way to update devices with older firmware is to update the satellite in two firmware update increments.
Please let us know if you have additional questions!
If you can provide the current firmware on your satellite I would be happy to create a road map for you!
Best,
Kevin
Community Team
- phlying1Oct 07, 2023Aspirant
Looks like it happened automatically so I'm all set. Thank you everyone for getting me through this.
- FURRYe38Oct 07, 2023Guru - Experienced User
