phlying1
Oct 04, 2023Aspirant
RBR50 Firmware downloads the wrong file (RBR50V2)
 The download to manually update my RBR50 (https://www.netgear.com/support/product/rbr50#download)  downloads the wrong file. It downloads RBR50V2 and then the manual updload fails.   Please provide t...
- Oct 06, 2023If you can get it connected to the RBR or connect it via ethernet to the RBR, log into it's web page and get it updated manually. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
phlying1
Oct 06, 2023Aspirant
ALL FIXED! Thank you! I never would have figured that out in a million years.
I got one RBS up to date and the other is on way old firmware. I don't really need a second one but is there a way to get that one caught up now that the router is on FW V2.7.4.24?
Oct 06, 2023Guru - Experienced User
Enjoy. 📡
