Ladnemk7
Feb 11, 2021Tutor
RBR50 firmware has never been updated
I foolishly assumed that my Orbi would auto update firmware, but in the process of troubleshooting this morning realized that is SO not the case. My system is currently running firmware version 1.4....
- Feb 11, 2021
You'll need to update to v2.0.0.74 on the RBS first then RBR. Then you'll need to apply v2.2.1.212, Then you can go to more recent versions or check to see what the RBR finds for you.
Ladnemk7 wrote:I foolishly assumed that my Orbi would auto update firmware, but in the process of troubleshooting this morning realized that is SO not the case. My system is currently running firmware version 1.4.0.34.
Do I need to manually install all firmware versions released since, or can I jump to a more recent version? I apologize in advance for being so obtuse!
vajim
Feb 11, 2021Master
FURRYe38 wrote:You'll need to update to v2.0.0.74 on the RBS first then RBR. Then you'll need to apply v2.2.1.212, Then you can go to more recent versions or check to see what the RBR finds for you.
how about tell me if this would have worked:
you may want to perfrom a factory reset and then see what firmware the orbi grabs from the server and go from there.
you can do manual updates, however I believe you can not jump to the front of the line. From where you're at you may have to install a cetain version and then do another to get you current.
Ladnemk7
Feb 14, 2021Tutor
Thanks for the info in responses. Sorry for the delay in my response.
I completed a factory reset, no new updates were found in the process. I then attempted a manual upload for the update noted 2.0.0.74(RBR50-V2.0.0.74.img) for RBS and received the following response: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
| This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. |
- Ladnemk7Feb 14, 2021Tutor
Final update.
I decided to push through and attempt the next recommended update (2.2.1.212) for both RBS & RBR. Worked like a charm. Then, the automated system kicked in and prompted for 3 additional group updates. I am very proud to announce that my wonderful little Orbi system is now operating as it should with the most recent available update. (2.7.2.104) Thank you all so much for your time and advice. I will NOT fall into this type situation again.
- FURRYe38Feb 14, 2021Guru - Experienced User
Glad you got it working.
Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed.
Please mark your thread and solved so others will now.
Enjoy. :smileywink:
Ladnemk7 wrote:Final update.
- vajimFeb 14, 2021Master
Just make sure you leave it alone
