CeeBee513
Jan 05, 2021Aspirant
RBR50 Firmware Issue
I got a notification that my Orbi Router and Satellite had a firmware update available through the Android App so I started the update process. Ultimately the Satellite updated fine but the Router wo...
Jan 05, 2021Guru - Experienced User
FYI, v2.5.2.4 seems to be the last in the v2.5 line of FWs. NG hasn't given an auto update notification path to v2.6 or v2.7 from v2.5.
If users wish to update beyond v2.5, you'll need to manually download v2.6 FW files for 50 series Orbi and apply them manually over v2.5. RBS first then RBR lastly. v2.6 version is for USA and all other regions.
For users wishing to update to v2.7 versions, you'll need to manually download v102 FW files for 50 series Orbi and apply them manually. RBS first then RBR lastly. v2.7 versions is for USA region only.
CeeBee513
I have tried that already. I successfully got the Satellite to the 2.7 version, but I cannot get the Router to update to anything else at all. It is stuck at 2.5.1.16. I tried the update that it wants me to apply, which is 2.5.2.4 (both automatically and manually) and then I have tried the 2.6 version and the 2.7 version manually. Nothing is allowing it to move from 2.5.1.16.
- FURRYe38Jan 05, 2021Guru - Experienced User
Try using this process to get passed v16:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.- CeeBee513Jan 05, 2021Aspirant
FURRYe38 wrote:Try using this process to get passed v16:
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.Thanks for the suggestion, I will have to see if I have a laptop that has an Ethernet port. We don't have a Desktop in the house since my wife and I only use laptops and I know mine doesn't have an Ethernet port. I don't think hers does either unfortunately.
Also what browser are you using to update FW with? Recommended ones are IE11, Edge or Firefox.
- JgoldstiJan 05, 2021Star
Other key thing is to press and hold the reset button with the router off and keep holding for 30 seconds after you power on the router. I found netgear has an incorrect kB article that does not include this info.
the article posted by furry38e works...
