CeeBee513
Jan 05, 2021Aspirant
RBR50 Firmware Issue
I got a notification that my Orbi Router and Satellite had a firmware update available through the Android App so I started the update process. Ultimately the Satellite updated fine but the Router wo...
CeeBee513
I have tried that already. I successfully got the Satellite to the 2.7 version, but I cannot get the Router to update to anything else at all. It is stuck at 2.5.1.16. I tried the update that it wants me to apply, which is 2.5.2.4 (both automatically and manually) and then I have tried the 2.6 version and the 2.7 version manually. Nothing is allowing it to move from 2.5.1.16.
Jan 05, 2021Guru - Experienced User
Try using this process to get passed v16:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
- CeeBee513Jan 05, 2021Aspirant
FURRYe38 wrote:Try using this process to get passed v16:
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.Thanks for the suggestion, I will have to see if I have a laptop that has an Ethernet port. We don't have a Desktop in the house since my wife and I only use laptops and I know mine doesn't have an Ethernet port. I don't think hers does either unfortunately.
- FURRYe38Jan 05, 2021Guru - Experienced User
Also what browser are you using to update FW with? Recommended ones are IE11, Edge or Firefox.
FURRYe38 wrote:Also what browser are you using to update FW with? Recommended ones are IE11, Edge or Firefox.
I initially tried the Android App and then when I switched to trying the web interface I used Firefox. Its really weird because it behaves as if everything updated fine, no errors or anything but it just won't really update.
- JgoldstiJan 05, 2021Star
Other key thing is to press and hold the reset button with the router off and keep holding for 30 seconds after you power on the router. I found netgear has an incorrect kB article that does not include this info.
the article posted by furry38e works...
