Spudger
Nov 20, 2019Aspirant
RBR50 Firmware Update & Documentation
having issues with WiFi connectivity since updating the Orbi to 2.5.0.38 i see that there is a HotFix 2.5.0.40, per the docuemntation it states: To manually update your satellite’s firmware: ...
- Nov 20, 2019
Need to use a PC and web browser to log into the RBRs web page to find the FW update section there.
Also it's recommended to factory rest and setup from scratch after loading FW if problems are seen after FW updates are applied.
Nov 20, 2019Guru - Experienced User
