nknelson56
Aug 08, 2024Initiate
RBR50 Firmware Update page just spins
My Orbi RBR50 is at firmware version v2.7.4.24. When I go to the Firmware Update page (in the web browser), the page just spins with "Please wait a moment..." and never shows anything. I see that the...
- Aug 08, 2024
Can you get to the manual tab to manually load the FW file at all?
Happens when using a different browser?
Aug 08, 2024Guru - Experienced User
nknelson56
Ah, thank you for that "different browser" suggestion. I should know better! I can access that page just fine with Chrome (my default browser is Firefox).
- FURRYe38Aug 08, 2024Guru - Experienced User
FireFox should work too. Might clear out it's browser cache data and try again. Glad a different browser works though.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
