joyammi
Jun 16, 2018Tutor
RBR50 Firmware update Problem
I logged into my Orbi Netger app and it said there was a Firmware update. So I updated. Now my Orbi does not show up in Wifi newtorks. That means I cant get into my Circle App either. I tried to fact...
Jun 17, 2018Guru - Experienced User
Use a wired lan cable PC connected to the router.
Press in the reset button on the Orbi router until the top LED turn amber or yellowish then release the reset button. Should be only 15 seconds. Wait for the WHITE led to blink fast, then will start to pulsate slowly, when you see this, log into the routers web page at 192.168.1.1 with the wired PC and a web browser, IE11 will work. Walk thru the set up wizard and fill it out. Write down the new log in info and SSID names and PW you set up.
joyammi
Jun 23, 2018Tutor
Thank you for the response. However, as indicated in my original post, the router will NOT reset. I have unplugged, powered off etc, and still cannot get it to blink amber and pulse white. In addition, I have tried 3 browsers, clearing caches and cookies and cannot login to the routers web page.
So I suppose my first problem would be getting the router to reset.
