rabbw
Apr 01, 2021Guide
RBR50 Firmware Update problem
I received an email that there was a Firmware update for my router. I tried to do it with the Netgear app but I received a Firmeware Check Error. I then downloaded the firmware to my laptop and read ...
- Apr 01, 2021
Avoid using the Orbi app for any FW updates. You can do this if you want to update FW:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelliteIf you do, update the RBS first then RBR lastly.
rabbw wrote:I received an email that there was a Firmware update for my router. I tried to do it with the Netgear app but I received a Firmeware Check Error. I then downloaded the firmware to my laptop and read the instructions for installing. One place tells you to log into routerlogin.net and another place in the instructions specifies orbilogin.com. I tried both and attempted to login with username of admin and the password I set up when I installed the Orbi system. I get a 500 internal server error with both. Any suggestions?
rabbw
Apr 04, 2021Guide
Thanks to everyone who responded to my note regarding my firmware not updating. A special thanks to FURRYe38 for his guidance. Rebooting while connected to my laptop worked and I was able to update the firmware and all is well.
