helpme1234
Dec 19, 2020Aspirant
RBR50 firmware update-this firmware file is incorrect
I have an Orbi RBR50 and am unable to update the firmware. The message in the autoupdate section of the router management is that the "update has failed". I have tried repeatedly to manually update a...
Dec 19, 2020Guru - Experienced User
- helpme1234Dec 19, 2020Aspirant
Thanks for the quick reply.
Firmware: V2.1.4.16_1.0.0.1
Modem: Fios G1100
ONT: Verizon 1-211M-L
I should add that the Orbi is not functioning as the router but is in AP mode.
- FURRYe38Dec 19, 2020Guru - Experienced User
Ok on AP mode. Your good then.
helpme1234 wrote:I should add that the Orbi is not functioning as the router but is in AP mode.
Ah ok, so your on a old version which you need to update to v212 I believe on the RBS first, then RBR lastly. Once these are at v212, you can Go directly to 40 on the RBS, I believe then try on the RBR lastly.
If you can get access to the RBS web page, send the FW file to the RBS web page first. Then update the RBR.
Your ISP mode has a built in router just FYI. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- helpme1234Dec 19, 2020Aspirant
The RBS's are already at version V2.5.1.16
I had tried to run the modem in bridge mode, but the connection was unstable, in part due to the Verizon periodic change in IP addresses. I spent hours on this. I have the verizon radios off and am running in AP mode. I'll try your middle suggestion, but everything I've found so far suggests that AP mode is the only way to get this to work. Thanks again.
