helpme1234
Dec 19, 2020Aspirant
RBR50 firmware update-this firmware file is incorrect
I have an Orbi RBR50 and am unable to update the firmware. The message in the autoupdate section of the router management is that the "update has failed". I have tried repeatedly to manually update a...
helpme1234
Thanks for the quick reply.
Firmware: V2.1.4.16_1.0.0.1
Modem: Fios G1100
ONT: Verizon 1-211M-L
helpme1234
I should add that the Orbi is not functioning as the router but is in AP mode.
- FURRYe38Dec 19, 2020Guru - Experienced User
Ok on AP mode. Your good then.
helpme1234 wrote:I should add that the Orbi is not functioning as the router but is in AP mode.
