RDMSYS
Jun 05, 2020Star
RBR50 Firmware Update
I have a notification for new firmware (V2.5.1.16). However when I do the check, the router firmware is found but my Satellite stays at Please Wait A minute for 5 minutes then fails. I would like to ...
- Jun 06, 2020
It usually should do everything, however maybe some times that doesn't work. So the alternative method of manually loading FW is available. Glad it worked for you. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
RDMSYS
Jun 05, 2020Star
Thanks but I would rather let it do it. I was thinking of doing it via the app. I'm still not sure that it would have issues or not.
Jun 05, 2020Guru - Experienced User
RDMSYS wrote:Thanks but I would rather let it do it. I was thinking of doing it via the app. I'm still not sure that it would have issues or not.
"let it do it" doesn't seem to be working. You can leave it as is but I wouldn't recommend updating via the app, especially if you're already having issues. Reason why is it tends to be the devices that were updated via the app or wireless that we tend to see corrupt firmware issues on.
But again, up to you.
