RDMSYS
Jun 05, 2020Star
RBR50 Firmware Update
I have a notification for new firmware (V2.5.1.16). However when I do the check, the router firmware is found but my Satellite stays at Please Wait A minute for 5 minutes then fails. I would like to ...
- Jun 06, 2020
It usually should do everything, however maybe some times that doesn't work. So the alternative method of manually loading FW is available. Glad it worked for you. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
RDMSYS
Jun 05, 2020Star
OK, I did it via the web. First it did update the router. Then came back and the satellite worked. Never saw this before as usually it does both at same time.
Thanks all...
Jun 06, 2020Guru - Experienced User
Enjoy. :smileywink:
