JitM
Dec 24, 2020Aspirant
RBR50 firmware update
I have got following email from Netgear for my RBR50. We've Enhanced Your Product's Security. Please Update to the Latest Firmware. But when I check for updates from app it shows no new firmwar...
- Feb 10, 2021
Be sure to make a back up configuration to file for safe keeping on the RBR. Helps save time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
vajim
Feb 09, 2021Master
But when I check for updates from app it shows no new firmware is available.
I am on V2.5.2.4 not sure if I am missing any important updates in UK.
Regards
1. forget the app. IF you must check, try via PC login
2. IF it were related to an actual security vulnerability then NG would auto push it. No action required.
3. IF you want to upgrade the choice is yours with caution as always since these firmware release are known to have bugs
