JitM
Dec 24, 2020Aspirant
RBR50 firmware update
I have got following email from Netgear for my RBR50. We've Enhanced Your Product's Security. Please Update to the Latest Firmware. But when I check for updates from app it shows no new firmwar...
- Feb 10, 2021
Be sure to make a back up configuration to file for safe keeping on the RBR. Helps save time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Feb 09, 2021Guru - Experienced User
Next version after v4 is v40:
It's one that may have not been put up on the auto update servers so it may not appear as a notification on the RBRs web page.
v104 is also available. it's on the auto update server however you'd have to manually update to v40 I believe first to see v104. Or you can manually download and manually update to v104 directly with a wired PC and web browser:
Or you can keep what you have loaded as well. Up to you though.
But when I check for updates from app it shows no new firmware is available.
I am on V2.5.2.4 not sure if I am missing any important updates in UK.
Regards
- vajimFeb 09, 2021Master
FURRYe38 wrote:Next version after v4 is v40:
Proceed with caution and ask yourself why this may not appear as a notification on the RBRs web page and WHY users in here keep posting stuff like this???
