JitM
Dec 24, 2020Aspirant
RBR50 firmware update
I have got following email from Netgear for my RBR50. We've Enhanced Your Product's Security. Please Update to the Latest Firmware. But when I check for updates from app it shows no new firmwar...
- Feb 10, 2021
Be sure to make a back up configuration to file for safe keeping on the RBR. Helps save time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
JitM
Feb 10, 2021Aspirant
Thanks to All who responded this thread.
I have got new iphone app update of Netgear and after that I can see 2.7.2.104 version available to update. I have added the screenshot. I will try it over the weekend.
Thanks
alokeprasad
Feb 10, 2021Mentor
Strongly advise to use the web interface of the RBR50 instead of the smartphone app if you proceed.
How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
- jwh49Feb 10, 2021Aspirant
The firmware update was successful since my WiFi network is up and running after applying it using the updated Orbi iPhone app. I just cannot login using the correct password, serial number and secuity question answers.
- FURRYe38Feb 10, 2021Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Thanks, that worked. Both the RBK50 and RBS50 now have current firmware but the RBW30 will NOT install, after downloading, even using Manual upload.
