JitM
Dec 24, 2020Aspirant
RBR50 firmware update
I have got following email from Netgear for my RBR50. We've Enhanced Your Product's Security. Please Update to the Latest Firmware. But when I check for updates from app it shows no new firmwar...
- Feb 10, 2021
Be sure to make a back up configuration to file for safe keeping on the RBR. Helps save time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
jwh49
Feb 10, 2021Aspirant
Thanks, that worked. Both the RBK50 and RBS50 now have current firmware but the RBW30 will NOT install, after downloading, even using Manual upload.
Feb 10, 2021Guru - Experienced User
Enjoy. :smileywink:
