Corkym13
Jan 28, 2025Initiate
RBR50 firmware update
Just doing update on firmware via the web. Both have downloaded for the Orbi 95 and Satellite but it's now been "updating" for over 30 minutes. How long should it take? Previously it's been a coup...
- Jan 28, 2025
Sorted! I read about a manual update and did that. It seemed to stall again but I needed up rebooting my laptop to find that the latest firmware had updated.
Corkym13
Jan 28, 2025Guru - Experienced User
glad you got it fixed!
We usually recommend a manual update on here. Tends to have less issues than the app based update.
