Taylorpah
Sep 21, 2020Follower
RBR50 firmware V2.5.2.4 drops out frequent when streaming ABC radio
When i listen to the news every morning on my iPhone, the sound drops out and the app icon starts whirling. Turning OFF WFI on my iPhone brings sound back straight away.
No issues connectioning to work, although that is via Ethernet cable.
Can you point me at the log files / enabling debug logging so I can send some info ?
I installed them 18 may 2020 and the support options have expired.
thanks
Alex
1 Reply
Has a power OFF of the RBR and RBS for 30 seconds since last FW update been performed?
Is this the only service that you have problems with?
Does this happen with other devices using same service?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerTry disabling the following and see:
Armor, Circle,One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026router ip address/debug.htm in a web page you'll find debug capture option.
