pgeenhuizen
Oct 02, 2023Aspirant
Rbr50 firmware V2.7.4.24
I have several port forwarding rules that work just fine. I need to move my web server to another host and to test it's connectivity I set up a rule to direct port 8080 to port 80 on the new server,...
CrimpOn
Oct 02, 2023Guru - Experienced User
What platform is the web server on?
Windows Firewall, for example, has separate rules for private network (local LAN) and public (the internet).
- pgeenhuizenOct 02, 2023Aspirant
Thanks for the repsonse, I should have added port forwarding to my subject to make it a bit more clear.
I'm running strictly Linux hosts.
As I said I have a port forwarding rule from the internet port 80 to internal IP port 80, so I added an new rule to forward internet port 8080 to internal new IP port 80.
It's been several years since I set up my router and all the rules I set up worked without a problem but trying to set up this new rule has me buffaloed
Pete
- CrimpOnOct 02, 2023Guru - Experienced User
Did you get a warning message when setting up the Port Forwarding that "These ports are being used by the system..."
and the change will not take effect until the router is restarted?
Nope the change went without any errors or popups,
I just changed the external port to 8000 and tried to connect to connect and this is the error
An error occurred during a connection to <my domain>t:8000. SSL received a record that exceeded the maximum permissible length.
