pgeenhuizen
Oct 02, 2023Aspirant
Rbr50 firmware V2.7.4.24
I have several port forwarding rules that work just fine. I need to move my web server to another host and to test it's connectivity I set up a rule to direct port 8080 to port 80 on the new server,...
CrimpOn
Oct 02, 2023Guru - Experienced User
What platform is the web server on?
Windows Firewall, for example, has separate rules for private network (local LAN) and public (the internet).
pgeenhuizen
Thanks for the repsonse, I should have added port forwarding to my subject to make it a bit more clear.
I'm running strictly Linux hosts.
As I said I have a port forwarding rule from the internet port 80 to internal IP port 80, so I added an new rule to forward internet port 8080 to internal new IP port 80.
It's been several years since I set up my router and all the rules I set up worked without a problem but trying to set up this new rule has me buffaloed
Pete
