pgeenhuizen
Oct 02, 2023Aspirant
Rbr50 firmware V2.7.4.24
I have several port forwarding rules that work just fine. I need to move my web server to another host and to test it's connectivity I set up a rule to direct port 8080 to port 80 on the new server,...
pgeenhuizen
Thanks for the repsonse, I should have added port forwarding to my subject to make it a bit more clear.
I'm running strictly Linux hosts.
As I said I have a port forwarding rule from the internet port 80 to internal IP port 80, so I added an new rule to forward internet port 8080 to internal new IP port 80.
It's been several years since I set up my router and all the rules I set up worked without a problem but trying to set up this new rule has me buffaloed
Pete
CrimpOn
Oct 02, 2023Guru - Experienced User
Did you get a warning message when setting up the Port Forwarding that "These ports are being used by the system..."
and the change will not take effect until the router is restarted?
- pgeenhuizenOct 02, 2023Aspirant
Nope the change went without any errors or popups,
I just changed the external port to 8000 and tried to connect to connect and this is the error
An error occurred during a connection to <my domain>t:8000. SSL received a record that exceeded the maximum permissible length.
