kenadra
Mar 16, 2021Aspirant
RBR50 Firmware Version V2.7.2.104 WiFi Consistently Losing Internet Connectivity
I recently updated the firmware, and then within a day I am consistently having this issue. The Spectrum modem and even router's connection to the internet are fine (I can do speed test in the Orbi ...
- Apr 13, 2021
Thanks all for DNS and Daylight Savings suggestions. My original config was already customized to use 1.1.1.1 and time.google.com. I used Google's leap-smearing NTP because my computers also use it. However, changing these settings did not fix the issue. As a getaround I have set up my outward facing ISP connection to first go to a Ubiquiti Edge Router X which sets up two different LANs. My home office is on one, and my Orbi mesh routers use another (and the Orbi gateway address is different from the ERX interface address presented to it as the "internet"). After a couple weeks I have not had my WiFi strangely lose its routing abilities with all my home devices. Plus I get the benefit of being able to reboot Orbi without losing internet in the office. So this does not fix the issue because ultimately I have done nothing with the Netgear system, but it does seem to correct whatever is going wrong with the new firmware. I absolutely think it is the new firmware version and not my settings. Extremely strong correlation with new update, as many others have expressed. Not everyone can change their network setup so this needs to be fixed by Netgear.
719G2
Mar 19, 2021Initiate
I am having the same issue. This is is a serious issue because the wifi is completely down fo rmobile devices and all chromebooks.
the only exception that I am experiencing is my desktop. The desktop PC able to see and use the wifi wiout issue.
I have tried to change password and remove security (PW) but this does not solve the wifi problem.
sgtgchjr
Mar 23, 2021Aspirant
I am having the same issue. It started last week. I have my own modem with spectrum, I just go in and reboot the router. It started happening a couple of times a day at first but now it is about every other day.
- NullZeroNullMar 23, 2021Tutor
In the advanced settings, if you UN-check "Automatically adjust for Daylight Savings Time" that may fix your issue. Seems to be working for me, at least.
- vajimMar 23, 2021Master
NullZeroNull wrote:In the advanced settings, if you UN-check "Automatically adjust for Daylight Savings Time" that may fix your issue. Seems to be working for me, at least.
I believe the moderator here said to uncheck the Traffic Monitor
