SeanFisch
May 01, 2023Aspirant
RBR50 Firmware
Trying to update the router firmware. RBR50. Currently on version V2.0.0.74 When I use the ap, I just get an error When I log into 192.168.1.1 then Advanced/Admin/Firmware update Auto u...
- May 01, 2023
Back in 2019, Netgear discovered that the software engineers had assumed that the Orbi firmware image would never grow larger than a certain size and built a check into the firmware update software to reject any image greater than that size.
Alas, the image DID grow larger, and was rejected by the update routine. Netgear released a special version of firmware where the only thing it did was remove that size limit. This version has to be installed manually on both satellite and router before they will accept any newer version. See:
https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212
CrimpOn
May 01, 2023Guru - Experienced User
SeanFisch
May 04, 2023Aspirant
Thanks for posting this. This worked.
