GeniusMBM
Jul 15, 2021Aspirant
RBR50 flashing white light / not working anymore
I've seen a similar problem but going through the solutions has not helped. I've had it for 2 years 7 months with no prior issues but now I believe it's soft-bricked with no return. I have 4 RBS5...
Jul 16, 2021Guru - Experienced User
No, the RBS50's don't have an AP mode.
Are you sure the RBR is bricked?
What's actually happening with it?
Have you tried tftp/nmrpflash to fix it?
- GeniusMBMJul 17, 2021Aspirant
Hi plemans,
It does seem like the router is now completely dead, please see my reply above to FURRYe38.
Since the RBR50 is now seemingly dead, is there any way to make use of the RBS50's using another router or do they have to be operated by the RBR50?
I would like to avoid buying another RBR50 as I would be forced to buy a satellite along with it. Please advise for any other potential solutions. Thanks!
