Etmom1
Sep 06, 2020Aspirant
RBR50 Flashing White light
Lost power yesterday and the router stopped working (no power surge, it's on a UPS). Now, it continually flashes the white ring on top. The power light on the back is green. Have confirmed that th...
Mstrbig
Sep 07, 2020Master
Was your Orbi's network cable protected as well? A sugre can come through network cable as easy as through power. That could affect and damage the Orbi's ports.
Make sure orbi is off.
Unplug the router leaving the power supply plugged in for a good 3 minutes.
Hold in reset button, plug in power supply and turn on orbi still pressing reset. Do not let go until you see a red power light. Let go of reset and the power light should turn green and top light flashing while.
Reinstall orbi.
Reinstall orbi.
Etmom1
Sep 07, 2020Aspirant
Tried this and still flashing white ring.
