azrai88
Nov 06, 2021Aspirant
RBR50 frequent losing internet connection
Dear all, My devices keep disconnected from ORBI WIFI network frequently almost every 1-2 minutes and reconnected back, and then keep repeating. As there is no problem to connect to the inter...
CrimpOn
Nov 06, 2021Guru - Experienced User
Can you describe which type of devices drop and regain WiFi connection?
Is it every device?
DoS attacks do not cause the Orbi to pause WiFi.
- azrai88Nov 06, 2021AspirantAll types of devices (PC laptop and desktop, iPhone and iPad to be specific) drop and regain the WiFi connection, happen non-stop.
Yes, every device. - azrai88Nov 09, 2021Aspirant
Any idea anyone? Any idea why the WiFi behaves that way (drop and immediately reconnect immediately - happens every 2-3 min for all type of devices, non-stop) but running just fine when using cable?
Been using RBR50 almost without interruption for almost three years. Gave this to my parents while me upgraded to RBR850, but they enjoyed it just for two months and returned it to me.
Configuration issue? hardware malfuntion? need to downgrade the firmware? seems few others experience the same.
Appreciate any support or feedback.
