azrai88
Nov 06, 2021Aspirant
RBR50 frequent losing internet connection
Dear all, My devices keep disconnected from ORBI WIFI network frequently almost every 1-2 minutes and reconnected back, and then keep repeating. As there is no problem to connect to the inter...
CrimpOn
Nov 06, 2021Guru - Experienced User
Can you describe which type of devices drop and regain WiFi connection?
Is it every device?
DoS attacks do not cause the Orbi to pause WiFi.
azrai88
All types of devices (PC laptop and desktop, iPhone and iPad to be specific) drop and regain the WiFi connection, happen non-stop.
Yes, every device.
Yes, every device.
