Nicolas72
Sep 05, 2019Guide
RBR50 fw 2.3.5.30 wifi very instable
Hi, I'm running one RBR50 and RBS50 wirelessly backhauled since several months without any issue. I upgrade to last fw 2.5.3.50 two days ago. Since the upgrade, the wifi is very unstable. Most o...
Anonymous
Sep 06, 2019
Nicolas72 wrote:Hi,
Since the upgrade, the wifi is very unstable. Most of the time it's so slow it's simply not usable. It is working then suddenly it becomes very slow for a while.
My internet connection is working well and wired connections are working also very well. No special settings configured. Router is set up in router mode.
Does anyone already encountered such a behavior with this fw?
Many thanks in advance for your help.
Nicolas
Why did you upgrade?
- Nicolas72Sep 06, 2019Guide
No particular reason, I was running an "old" 2.2.X one
I though upgrading once in a while was not a bad idea to get security patches or so ...
- AnonymousSep 06, 2019
Nicolas72 wrote:No particular reason, I was running an "old" 2.2.X one
Lesson learned.....not all firmware is created equal. If your system is working, no need to upgrade the firmware. NG will push FW with major revisions automatically.
- AFDOct 12, 2019Luminary
Similar issues ,. but in my case I didnt perform any update activity , Autoupdate is running again in the Orbi Systems? .
As you mentioned , my system was running perfectly fine , and now I have a terrible issue not only with the persomance but with no devices connected to the satellite .
