rob9999
Apr 02, 2018Aspirant
RBR50 generating resolving hosts error
I have 1 RBR50 and 3 RBS50 units. Often (> 50%) I an receiving a 'resolving hosts' error on my computer. I find that I am connected to the nearest RBS50 with a stong signal. I then connect to ...
Apr 02, 2018Guru - Experienced User
What FW version are you using?
Have you set up any reserved IP addresses ON the router for your PCs and devices?
rob9999
The firmware level is V2.1.2.18
I have no reserved addresses. I know networking and this is baffling.
- FURRYe38Apr 03, 2018Guru - Experienced User
Try the new v2.1.3.4. Do a factory reset on both router and Satellites then set up from scratch. Skip setting up the Satellites.
I would also do a IPCONFIG /release, then /renew then /flushdns on your PCs. Reboot reset of mobile devices AFTER you have set up the router.
Test. Then set up the Satellites.
- lindsay_s_ChiMay 27, 2018Aspirant
Did you find a solution? I am having the same problem (Resolving Host error...)
- FURRYe38May 27, 2018Guru - Experienced User
What model Orbi system do you have?
