rob9999
Apr 02, 2018Aspirant
RBR50 generating resolving hosts error
I have 1 RBR50 and 3 RBS50 units. Often (> 50%) I an receiving a 'resolving hosts' error on my computer. I find that I am connected to the nearest RBS50 with a stong signal. I then connect to ...
rob9999
The firmware level is V2.1.2.18
I have no reserved addresses. I know networking and this is baffling.
Apr 03, 2018Guru - Experienced User
Try the new v2.1.3.4. Do a factory reset on both router and Satellites then set up from scratch. Skip setting up the Satellites.
I would also do a IPCONFIG /release, then /renew then /flushdns on your PCs. Reboot reset of mobile devices AFTER you have set up the router.
Test. Then set up the Satellites.
- lindsay_s_ChiMay 27, 2018Aspirant
Did you find a solution? I am having the same problem (Resolving Host error...)
- FURRYe38May 27, 2018Guru - Experienced User
What model Orbi system do you have?
What FW version are you using?
Have you set up any reserved IP addresses ON the router for your PCs and devices?
