Oldironsides
Mar 10, 2020Guide
RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
Hello Orbi Community, Thank you for taking the time to view my post. Just bought the Orbi AC3000 kit from costco to maximize my 1gig internet speed provided by Comcast. I must say my wifi sp...
Mar 10, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- OldironsidesMar 10, 2020GuideThanks you FURRYe38 for replying to me.
The router and the satellite are about 20 feet away from each other. I have no coaxial in living room. So main router in bedroom hardwired to modem. Next room over, I have the satellite behind my tv, hardwired to my PC.
I made the changes in which you suggested, rebooted the router and satellite and still am getting lower than desired speeds. Did get one test at 520Mbps, so we are getting better.
Any other suggestions?- FURRYe38Mar 10, 2020Guru - Experienced User
20 feet is too close between the RBS and RBR...
- OldironsidesMar 11, 2020Guide
Thank you. I will relocate the router to anoher room and place the satellite a little further away. I will report back tonight after work.
- OldironsidesMar 11, 2020GuideMoving the satellite and router further apart did not correct my wired speed from the satellite.
- theoakMar 11, 2020Luminary
Any other suggestions?How many devices are hardwired in your bedroom? You might want to consider a Powerline type solution from the plug the Orbi Router is on (or near) to a plug in the bedroom and then hardware that to your computer or other devices in your bedroom. Considering the rooms are that close, you would probably get really good speeds via Powerline. I would not go less than Powerline 1200 (AV2). They have Powerline 2000 (2 Gbit) out now with multiple network ports also. You can get a pair for a decent price.
I run powerline in my home for some cameras that I have on the edges of my wireless. Due to the distance and the hops that are probably happening in my electrical wiring, my connection rate is far from stellar; however, it is waaay more than enough for the bandwidth of a single camera. One of these days I may feel energetic and go in my crawl space and run some Cat 6/a or something.
I have been thinking about trying powerline adapters. However I wanted to just use one solution if available....
Question: If I do decide to go with powerline adapter, should I go wall socket -->powerline adpater-->orbi router<-->modem
or
wall socket-->powerline adapter-->modem (I do have 2 ethernet ports on the modem)
It may be trial and error, but any advice would be much appreciated. I am going to see tonight if the proper distance between router and satellite will help my speed. If not powerline baby.
